Oggi è lunedì 29 giugno 2026, 7:29
 Oggetto del messaggio: Disponibile firmware per Ecos 2 3.6.1
MessaggioInviato: sabato 22 dicembre 2012, 9:04
Disponibile il nuovo firmware per la Ecos !!!
Ecco il dettaglio
General
- ADD: RailCom Support for ECoSBoost. In combination with ECOSBoost, even Central Station Reloaded can use RailCom now (however disabled by default)
- CHANGE: External Booster Control Timing changed to the original setting before version 3.4.0
- ADD: Added a "Hosenträger" icon, 2 aspects, Computerinterface 33
- ADD: Added a "Hosenträger" icon, 4 aspects, lefthand, Computerinterface 34
- ADD: Added a "Hosenträger" icon, 4 aspects, righthand, Computerinterface 35
- CHANGE: For routes, the symbol of the computer interface changed to 42
- ADD: Added a accessory symbol without real track output as dummy in routes.
- ADD: Support for F22, F23 for locomotive control
- CHANGE: in the Multicontrol screen, you can now change direction and speed on non-selected locomotives. (Only for ECoS 50200)
- ADD: Shuttle train symbol shown also on Multicontrol screen
- ADD: Using Multicontrol screen, you can enter the locomotive menu by clicking on the selected locomotive icon
- CHANGE: M4/RailComPlus engines will automatically entered into locomotive favourites list #1 (like the manually entered locomotives)
- BUGFIX: RailComPlus detection now works also with Tams-Decoders
- BUGFIX: The text that displays when a new locomotive is detected via RailComPlus is now located on correct position.
- ADD: NMRA manufacturer list updated
- ADD: "Ok and next" key added to the keyboard when editing text of accessories and routes
- BUGFIX: Motor-driven throttles will now follow movement also when operating in track control
- ADD: you can now edit links in the track diagram
- ADD: The IP device name can now be edited in the IP setup dialog. Will be published via DHCP
- ADD: You can now ask the ECoSBoost to blink for identification. We added a a button for it in the menu
- BUGFIX: No more crash when changing s88 modules from 8/16 without having any s88 module
- BUGFIX: No more crash of ECoS when exiting the menu while DCC programing is still active
- ADD: Shift key in the keyboard
- CHANGE: Screen calibration now turns off the track power
Track Layout:
- ADD: Added a function symbol without track, computerinterface 18
- ADD: Added a function symbol with track, computerinterface 36
- ADD: Added a unidirectional "Start-Stop-Button", computerinterface 37
- ADD: Added a dummy symbol, 2 aspects, computerinterface 38
- ADD: Added a dummy symbol, 3 aspects, computerinterface 39
- ADD: Added a dummy symbol, 4 aspects, computerinterface 40
- ADD: Added a bidirectional "Start-Stop-Button", computerinterface 41
Visitano il forum: cortez e 35 ospiti
