Oggi è giovedì 14 maggio 2026, 15:55
 Oggetto del messaggio: Disponibile firmware 3.7.0 per Ecos 2
MessaggioInviato: martedì 4 giugno 2013, 7:03
Sul sito esu e' disponibile il nuovo firmware 3.7.0
Ecco le nuove caratteristiche
New features
- Support for L.Net converter. You can find the user's manual under
http://www.esu.eu/download/betriebsanle ... /zubehoer/ (german language only at this time).
- New decoder profile for LokPilot V4.0 M4 decoder for usage under DCC. If you use this
decoder under M4, the automatic profile will be used.
Bugfixes and smaller changes:
- Optimized screen redraw to make the GUI a little faster
- Improved address assignement (matching) for all applications such as ECoSniffer, RailCom
Address Display, Locomotive categories in routes or L.Net converter: Thew new rules is as
follows: First, a locomotive having a sniffer address will be searched for. If no such
locomotive exists, a locomotive having the real address will be tried to find. This means
that in future, you don't need to have Sniffer addresses; you can use the real locomotive
addresses instead (if you set all sniffer addresses to "0"). Of course, for M4 locomotives,
you still need a sniffer address occasionally.
- ECoSDetectors will be showed with their names
- Fixed display of RailCom-enabled ports on ECoSDetector devices (before, even a ECoSDetector
Standard was shown as "RailCom" enabled).
- In the locomotive select screen, you can no longer create a locomotive with invalid
addresses
- Locomotive categories are initialized now.
- Locomotive categories removed from ECoSDetector Extension now.
- If you try to edit a consist and cancel the operation, ECoS should no longer crash.
- Fixed a display problem on the turntables
- When using a Märklin turntable, you can no longer select non-existing tracks
- The programming for a Märklin turntable works correctly again now.
- Fixed a display problem when using more than 32 s88 modules
- User defined locomotive pictures (icons) with embedded colour profile ( like used by
Gimp 8.2) do work correctly now.
- Fixed some errors on automatic detection on ECoSLink devices
 Oggetto del messaggio: Re: Disponibile firmware 3.7.0 per Ecos 2
MessaggioInviato: martedì 4 giugno 2013, 12:55
Curiosità :oops:
Ma le correzioni di errori o implementazione di nuove funzionalità sulla ecos, sono a discrezione dei progettisti o del team preposto oppure raccolgono informazioni e/o suggerimenti dagli utenti che correntemente la usano?
Thanks
:mrgreen:
MessaggioInviato: mercoledì 5 giugno 2013, 9:01
Nel sito ESU c'è un Forum (in lingua tedesca, inglese, olandese e francese) in cui puoi dare suggerimenti e chiedere nuove funzioni.
MessaggioInviato: mercoledì 5 giugno 2013, 9:04
Ah ok.
Chiedevo per curiosità :wink:
Visitano il forum: costa, Google [Bot] e 26 ospiti
